another computer/chip question for ccQjets...
Old Oct 9, 2002 | 10:40 PM
  #51
fattie92's Avatar
................guys im very frustrated...... iv spent over 500 bucks on my problem and still havent fixed it... i just put on the rebuilt carb today, with no luck...... car runs alot better/faster.. but problem still exists
Old Oct 9, 2002 | 10:48 PM
  #52
flyway190's Avatar
curious, when was the last time you adjusted your tv cable?
Old Oct 9, 2002 | 10:58 PM
  #53
fattie92's Avatar
new transmission was put in not even 4 months ago. and the problem existed before that happend.... here i made a new thread for my problem
https://www.thirdgen.org/techbb2/sho...hreadid=137219
Old Oct 9, 2002 | 11:21 PM
  #54
flyway190's Avatar
did you check its adjustment though?
Old Oct 9, 2002 | 11:31 PM
  #55
fattie92's Avatar
yeah its been checked. then tonight when i put the rebuilt carb on, i also put a 1"spacer and had to readjust it.
Old Oct 9, 2002 | 11:34 PM
  #56
flyway190's Avatar
ok just wondering, i adjusted mine not too long ago and the first time i manually shifted, it did something similar to what you're describing :shrug:
Old Oct 9, 2002 | 11:39 PM
  #57
fattie92's Avatar
im bout ready to sell it now ..... i just dont understand what it could be... i mean if it was valve float.. then it wouldnt pull anymore, it kind of just sit there... i swear to *** there is someone sitting in my trunk with a remote ON/OFF switch that is just ****ing with me........GRRRRRRRRRRRRRRRR
Old Oct 10, 2002 | 08:42 AM
  #58
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
Prom and ECM
So an 87 H.O. computer will work. So I will not have any sensor conflicts or anything.
Old Oct 10, 2002 | 10:58 AM
  #59
Momar's Avatar
Are you sure you need a l69 computer. I have a lg4 computer but it was the newer version than yours that had the knock sensor. Do you know if it will work with the chip?
Ben
Old Oct 10, 2002 | 11:50 AM
  #60
fattie92's Avatar
Ben
from what i have read, no it wont work. go check out
http://www.diy-efi.org/mhonarchive/gmecm/msg00542.html
but it might not hurt to try i guess....
Old Oct 10, 2002 | 12:57 PM
  #61
Momar's Avatar
Well, I looked at that and I guess it says that you had to have a 87+ computer. It said it could be lg4 or l69. I dont know what years these motors stoped but I thought it was 87 but a guy on that board mentioned an 88. How long did the monte's have the ccc's?
Ben
Old Oct 10, 2002 | 01:00 PM
  #62
fattie92's Avatar
im pretty sure the cccarbs stopped in 88. when i went to the junk yard to get a computer from a 87 monte SS, the search came up with a 86 camaro, 87 monte ss, and a 88 caprice, and all the computers had the same numbers.
Old Oct 10, 2002 | 01:29 PM
  #63
Momar's Avatar
Could you give me that number. I could check it on my computer just to make sure before I go spending more money.
Ben
Old Oct 10, 2002 | 02:35 PM
  #64
fattie92's Avatar
i can get it for you, but im sorry to tell you that its gonna have to wait till tomorrow. im getting off work here in 10 min and im not going home tonight.
Old Oct 10, 2002 | 02:38 PM
  #65
Momar's Avatar
Thats fine anyway, because my car is not in any shape to drive yet anyway. It needs reasembled.
Old Oct 10, 2002 | 02:40 PM
  #66
fattie92's Avatar
ahh i c..well ill get back to you tomorrow...ill let you all know how it goes at the track tonight.
Old Oct 10, 2002 | 02:45 PM
  #67
flyway190's Avatar
Go to ACDelco's website and type in 1228079.
Old Oct 10, 2002 | 04:02 PM
  #68
Momar's Avatar
I did that and all of the vehicles it came up with were 87 and 88s but fattie92 even said that he found an 86 camaro and it had the same computer so I doubt thats all it came in unless the car was labeled wrong, or had the computer or engine swaped in the past. Is that the number to look for on my computer to see if it is the right one?
Old Oct 10, 2002 | 04:27 PM
  #69
flyway190's Avatar
I dunno if their info is all correct or not, but then again neither is a junkyard's. 1228079 is the computer that came in the kit along with the chip, so we know that one works with it. If fattie92 has a different one, we can add that to the list too. EDIT: which chip are you trying to use? an L69 or a ZZ4?
LG4TA, the '87 computer will likely work, but i'm not sure about the L69 chip. It probably won't work right without a knock sensor, but i don't think it will throw any codes.
Old Oct 10, 2002 | 04:41 PM
  #70
Momar's Avatar
Actually lg4ta you still have a 305 right. If so you could just get an aftermarket chip for your car and use the same computer. Actually considering you dont have a knock sensor because you have a 83 I would stay with the same computer and get an aftermarket chip for it. The reason he got an l69 computer was because it was the one that the 350 computer controlled carb chips were designed for, but the knock sensor was disabled in the version he got. The dont have any chips for the 305s that have the knock sensor disabled for the newer computers. If you did get a l69 computer you would have to run the 350 h.o. chip otherwise it would expect the sensors from a l69 including the knock sensor. I dont know that the 350 chip would cause problems on a 305, but you would probably be better off to take the safe route and get the chip for the 83 lg4. Ok, now that I have repeated myself several times trying to explain my thinking I think I will stop rambling.
Ben
Old Oct 10, 2002 | 05:29 PM
  #71
flyway190's Avatar
I have something to add to that. LG4TA: If you have a 305, don't even bother with the computer, there won't be much gain anyway without extensive mods. I doubt there will even be much gain on a 350, but I'm trying to fix a few kinks in my car's driveability. I see what you're talking about if it were a simple chip swap, but I think it is a little more complicated than that for your car because of the lack of a knock sensor, and it wouldn't be worth it if the computer you've got works just fine.
Old Oct 10, 2002 | 06:16 PM
  #72
Momar's Avatar
It is a simple chip swap if he gets like a hypertech chip for his car. It should help out because the lg4's timing curve is set to keep it from making as much power as the l69.
Ben
Old Oct 11, 2002 | 12:40 AM
  #73
flyway190's Avatar
I was thinking more along the lines of $35 max for a brand new L69 chip, as opposed to $125+ for an aftermarket.
Old Oct 11, 2002 | 07:21 AM
  #74
Momar's Avatar
True, bud did they make l69s without knock sensors? If so he could probably use a chip for one of those.
Ben
Old Oct 11, 2002 | 08:00 AM
  #75
fattie92's Avatar
dun dun dunnnnnnnnnnnnnnnnnnnnnnnn... yeah the track was HORRIBLE!!! my fastest time was a 15.9 with a shiiiiiiiiiiitty 2.5 60foot...that was only with 4 passes..i was gonna run later that night but my car didnt want to....(that cable from the gear selector to the transmission....the clip broke that held it to the tranny and i was stuck in 1st....) so i didnt get to duplicate or better my previous 15.6 run (still ****ty i should be at least 15.0)...
about the 350ho computer on the 305....id only do it if it was modded pretty good....or atleast a full exhaust. the computer will change your whole timing curve, and change air/fuel duing part throtle. but if i were you, i wouldnt waste my cash on it till you upgraded to a 350. i just upgraded casue im trying to track down a problem.
Old Oct 11, 2002 | 09:40 AM
  #76
Jaboski's Avatar
Car: 91 Firebird
Axle/Gears: 3.08
Fattie92, can you give me a brief description of what you did to your carb? Everyone keeps sending me to that article, and i have no idea what the hell its saying, so if you just tell me exactly what the hell i need to fiddle with it would make my life a hell of a lot easier.
Old Oct 11, 2002 | 10:23 AM
  #77
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
I think I get the picture now since the 83 LG-4 doesn't have the knock sensor the L-69 Chip won't work. So does that mean that the 83 Z28 L-69 HO had knock sensors? I guess I will get an aftermarket chip. Are they getting any cheaper now since they have been out there for awhile. I figure fewer people are buying chips for 83-92 since everyone is ditching their computers and more hit the junk yards so you would think the demand would be lower and they could have a fire sale.
Old Oct 11, 2002 | 10:53 AM
  #78
Momar's Avatar
Thats what I am not sure of is whether the 83 l69 had a knock sensor or not. I know that the l69 got the knock sensor before the lg4s did. The lg4s got knock sensors in 85 so the at least the 84 l69 had one but I dont know bout the 83. Maybe someone else might know and be able to help out here.
Ben
Old Oct 11, 2002 | 11:32 AM
  #79
fattie92's Avatar
what part do you need help with?? the AV tension, the rods and hangers, or the secondaries opening to 90* ? just so we dont cluter this board up with it, you can email me if you would like
fattie92@yahoo.com
Old Oct 11, 2002 | 12:56 PM
  #80
flyway190's Avatar
The kit specifies that the chip with knock sensor is a replacement for 83-86 L69's, and i saw a post on the history board that stated an 83 has a knock sensor. Try PMing RB83L69, i'm sure he'd be able to give a definite answer. A JET chip runs about $160 or so, and i couldn't find anyone with a hypertech chip but they usually run about $125. Usually lower demand = higher price. As i said before, if you pay that much for an aftermarket chip, you'll be disappointed in the difference. If you've got $125 or so to burn and only want to do cheap and easy mods, try these: an Accel ignition control module, open element air cleaner, and better secondary metering rods and hanger.
Old Oct 12, 2002 | 09:33 PM
  #81
Damon's Avatar
To my knowlege all years of the L-69 in the 3rd gen had a knock sensor. Now if the electronics are compatible every single year I don't know.
85-87 LG-4s had a knock sensor as well, which corresponds nicely to the years that they had their compression bumped up from 8.5:1 to 9.5:1 (same as the L-69).
Old Oct 15, 2002 | 08:21 AM
  #82
fattie92's Avatar
computers suck!! im trying to ditch it now! y spend more cash on a problem unknow, when i can swap it over and the problem be alllll gone?
p.s..if i do swap over, the L69 computer with conversion chip will be up for sale.
Old Oct 16, 2002 | 12:33 PM
  #83
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
AFAIK, all 83-86 L69 and 85-87 LG4 motors used the same knock sensor. In fact, I believe there's only two types of knock sensors: one is 100kOhm and the other is 3.9kOhm. Each type is available in 305 and 350 flavors.
For thirdgens, the 3.9k is only used on Speed Density TPI cars. All other thirdgens used the 100k to my knowledge, regardless of induction system or year. I'm not 100% certain what knock sensor 90-92 TBI cars used; if I had to guess, i'd say the 100k sensor.
Old Oct 20, 2002 | 09:04 PM
  #84
fattie92's Avatar
ok no more swapping for me, i changed my DR rods to CK's and put a K&N open element on and NO MORE PROBLEMS!! :lala: :lala: :lala:
Old Oct 20, 2002 | 09:10 PM
  #85
flyway190's Avatar
Glad to hear it. Sometime later you might try some CC's and see if they work even better. So how does it feel knowing that you really only needed to pay $0.60 to fix your problem?
Old Oct 20, 2002 | 09:17 PM
  #86
fattie92's Avatar
pretty damn stupid/good! lol... well im not sure if it was the open element, or the Ck's... or both of them... but its fixed!! all i care about. and technicaly i spent 50.60 (K&N filter with edelbrock open element was a package deal off ebay) ... but its not a bad thing that i upgraded all that other stuff... i just dont have to worry about any of that for a long time now!
how them DR's worken for you?
Old Oct 20, 2002 | 10:03 PM
  #87
Momar's Avatar
You'll have to get us some track times now that it is running properly.
Ben
Old Oct 20, 2002 | 10:33 PM
  #88
fattie92's Avatar
Ben
ahhh no more track times this year...and the next time i go to the track im gonna have 3.73's, posi, slicks and 150 shot of nitrous.
Old Oct 21, 2002 | 07:12 AM
  #89
Momar's Avatar
Do you think there is much difference since it runs right now? By the way, what rear gears do you have now?
Ben
Old Oct 21, 2002 | 07:51 AM
  #90
fattie92's Avatar
its gotta be a few tenths faster then it was, before it would stumble big time once at 4500, then after that it jsut didnt feel like it had much power.....but now it pulls hard to 6grand, no stumble at all. im pretty sure i have 3.23's out back....but im not positive. people keep tellin me "3.73's wont make a big differance".. ohh well! lol,, my gears are on the way out as it is(whinning), and im putting a posi in, so y not the 3.73's as well? im hoping for a 12.9 with the mods i got planned...but the thing that sucks is that im tryin to beat my friends integra that already runs 13.9's...and has ordered more stuff since then ....damn them fast economy cars!
Old Nov 26, 2002 | 09:42 AM
  #91
snowbird's Avatar
Any new developments?
Old Nov 26, 2002 | 12:33 PM
  #92
Momar's Avatar
Oh, and by the way, is that 13.9 on juice?
Ben
Old Nov 26, 2002 | 12:59 PM
  #93
fattie92's Avatar
yeah his 13.9 is on nitrous, and drag radials....its a quick car. now he is planning a complete engine rebuild so it can handle a 180 shot!!!
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
