WAY to rich
Old Oct 5, 2002 | 08:49 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
WAY to rich
i have an 84 camaro with an 87 rochester quadjra-crap on it. its been running very rich and if you look into the carb while its idling you can see it pouring fuel into the engine. i took the carb apart and everything looked fine to me, what do you think this could be? could the electronics have anything to do with it? theres a blue and a black wire that go into the top of the carb, what is this for? thx.
Old Oct 6, 2002 | 12:07 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
is the float level set right?
Old Oct 6, 2002 | 09:23 AM
TheViper's Avatar
Car: '84 Z28
i think it may be like 3mm off.
Old Oct 6, 2002 | 06:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the needle and seat are fine and the float level is right, check the return line on the fuel pump.
Old Oct 9, 2002 | 06:20 PM
TheViper's Avatar
Car: '84 Z28
i found out that it is the mixture controle selenoid. its not going up and down like it should. i think my best bet is just to get a new carb when i can afford one.
Old Oct 10, 2002 | 09:12 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: WAY to rich
Originally posted by TheViper
i have ... an 87 rochester quadjra-crap on it. ...
Your words betray your bias.
New carb - $250-$500. Plus the distributor you'll need to buy, adapter or intake manifold required because square-bores don't bolt to the factory manifold, TCC lock-up you'll need to rig up (assuming you have an auto tranny), poorer gas mileage you'll have to live with, etc.
New MCS - $39.99 plus shipping from http://www.carbs.net/quadrajet.asp .
Rebuilt E4ME for '84 Camaro - $329.50 + $50 core + shipping from same outfit, plus living happily ever after.
CC q-jets are not "crap". They are very good at delivering good driveability, gas mileage, and performance when set up right (and that doesn't take a lot of effort or money), and less expensive than most any other option out there if your car already has one on it. That's not bias talking, that's the voice of experience.
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
James Sutton
Sep 23, 2015 02:18 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
