Gurus, could this be right?
Old Sep 23, 2015 | 01:46 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
I'd been having error code 46, "low voltage to fuel pump." When I replaced instrument cluster, it went away. The printed circuit on the back of the old cluster was torn and crossed two lanes. Would that have generated the code? Would it have caused the fuel pump to run rich? I was getting 10mpg before; will check mpg in the future, but haven't run car enough to tell yet.
Old Sep 23, 2015 | 02:18 PM
Brother Al's Avatar
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Re: Gurus, could this be right?
It very well could have been the fuel gauge shorting out the fuel sending unit, which is also tied into the pump.... electrical gremlins are a PITA to track down, especially when multiple items are tied together via the ground wires &/or power supply.
GTAman
Sep 21, 2015 09:57 AM
badgta
Jan 1, 2003 09:24 AM
Kevs87TA
Dec 17, 2002 10:41 PM
iroc2nv
Sep 18, 2002 07:45 PM
Warlock
Mar 28, 2002 08:45 PM
