idle mixture srews! need help bad
Old Oct 16, 2002 | 08:16 PM
clh19_99's Avatar
how many turns out should i start with on the idle mixture screws. and what is considered a complete turn??????? i started with 4 turns out and thats 4 complete turns i think. liek go around once and then go around again to make a complete turn pls someone help
Old Oct 17, 2002 | 06:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
One complete turn is ..... one complete turn. 360° rotation.
If this is your factory computerized Q-Jet, the threads are a very fine pitch, and the screws do almost nothing anyway. Set them to 7 turns out from full in, and leave them alone; and make your idle mixture adjustments with the IAB valve.
Old Oct 17, 2002 | 07:28 AM
Damon's Avatar
I've noticed that, too. The threads are about twice as fine as earlier carbs, so it takes a lot of turns to make much movement. You can back them out so far they almost fall out of the carb and you still won't be excessively rich.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
mike_c
Aug 27, 2015 04:32 PM
86IROC112
Aug 21, 2015 07:20 PM
