vaccum hoses
Old Nov 17, 2002 | 10:27 PM
DansZ87's Avatar
Car: 91 Z28
Transmission: 700 R4
vaccum hoses
ok guys, i need some help, i have an 87 iroc with a 305 carb,
if ur staring at the engine from the fornt of the car, its seems like it seems like it connects to the thermostadt housing, u know on the top of it the little connector, then it runs to the left side to the back to the firewall, i cant figure out where it broke off from, so any help is greatly appreciated, thanks dan
Old Nov 19, 2002 | 08:58 AM
Vader's Avatar
DuPagè,
Check your hose routing against this, or the label inside the hood liner:
Old Nov 21, 2002 | 03:26 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
Vader that the one for the TA? hes got an Iroc. Im at work so I cant post it.
Old Nov 21, 2002 | 09:32 PM
Vader's Avatar
That was supposedly a Federal (non-California) Camaro 305.
Old Nov 22, 2002 | 02:36 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Ok thnks just making sure
Old Nov 24, 2002 | 11:38 AM
Vader's Avatar
What you are describing might be the TVS for the EFE system. There is a vacuum actuator at the outlet of the right exhaust manifold for the heat riser (EFE system). With no vacuum connected, it should be 100% open.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
st.evel07
Sep 19, 2015 09:24 PM
rjcme
Sep 5, 2015 01:23 PM
