Moisture
Old Nov 22, 2002 | 10:02 AM
Jaboski's Avatar
Car: 91 Firebird
Axle/Gears: 3.08
Moisture
Does moisture screw with my car? Its been rather wet in south earstern pa lately, my idles are a little wacky and it seems differen. Not overly concerned just wondering?
Old Nov 24, 2002 | 11:43 AM
Vader's Avatar
It can "screw with your car" if the ignition system is not in 100% condition. Check the cap and rotor for carbon streaking and moisture retention. A little silicone grease on the wire connections (boots) helps seal the system fairly well against atmospheric moisture/humidity.
Weak spark plug and coil wires can leak and short from moisture. Even dirt on the wires will contribute to this, since it will hold the moisture. Again, silicone grease on the boots will help seal the wires at the plugs.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
90Iroc
Apr 14, 2003 11:20 PM
radiateu2
Feb 16, 2003 08:23 AM
eyeROC
Jun 13, 2002 09:17 PM
