What size carb????
What size carb????
WHat size carb should I be using for a 305 CI engine? I got a TBI unit now and I want to go to CARB, but I dunno what size I should be using? 650 cfm?? maybe??
Car: 99 Formula
Axle/Gears: 342
A 600 should be fine for a 305. Though if you plan for a 350 in the future a 650 would be better, instead of buyin 2 carbs.
there's a formula on this board to figure out how much cfm you need, try a search.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
It'll load up like a MF'er driving in town or cruising at low rpms, once you open er up and get into the higher revs it'll go like a raped ape.
You'll consitently foul plugs on a regular basis-when u pull them out they will be black as night, so the motor won't run as well as it could, excessive fuel consumption to name a few draw backs.
When I had the 305 that I bought the car with I slapped a 600VS on there just cause I had it, worked extremely well, very responsive, decent mileage if I remember-but I really did'nt/and still don't care MPG. I will say this, even if all I had was a bone stock, low compression 350, I would'nt put anything smaller than a 750 on it. sbc 350's and 750cfm carbs go together like PB&J. Till u hop'em up anyways.
Originally posted by Ukraine Train
what happens if you have too much carb? like a 750cfm on a stock 305?
Billy Decker
Sep 4, 2015 03:46 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
