Important! Need 1206 capable DP
Old Nov 22, 2002 | 08:55 PM
xookered's Avatar
Greetings,fella's. I'm building a 383 around a set of Victor Jr. heads. 215 cc runners. Building for massive torque. Peak power at 6000 revs. Is there a dual plane manifold capable of being opened up to match a 1206 gasket. I love the stealth. Anyone know how much meat it's got?
Old Nov 23, 2002 | 12:18 AM
Jester's Avatar
You shouldn't run a dual plane with that. Get a good single plane, like a Team G or Vic jr.
Old Nov 23, 2002 | 01:15 AM
xookered's Avatar
Glad you were around Jester. I would prefer to go with a single plane. Will the Team G or Vic Jr. fit under the stock hood? I'm running a 3000 stall converter so torque isn't a problem. Hood clearance is my only issue. I know there's been debate over dual planes clearing. How can I fit a single plane?
Old Nov 23, 2002 | 12:19 PM
Jester's Avatar
Get the "Nascar approved" Team G from summit, pn 7530..it's really short. The difference between that and the other 2 versions are the plenum is shorter. Thats what I have on my motor..but unfortunatly I don't have a stock hood so I can't guaruntee anything.
But it's short..if its any taller than the stealth was it's not by much.
Old Nov 23, 2002 | 12:33 PM
xookered's Avatar
Thanks Jester! I just looked it up on the Holley site. The front is basically the same height as the Stealth. The back is about the same height as the Performer RPM. 2000-8000. Perfect!
Old Nov 24, 2002 | 04:12 PM
Odyssey's Avatar
A Victor JR would also fit under the stock hood with a holley carb on top. I dont know if an air filter would fit too since I dont run one... lol
ZZ3Astro
Aug 13, 2019 12:57 AM
Jorlain
Oct 8, 2015 01:57 AM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
