carb help
Old Nov 27, 2002 | 03:17 PM
chefdan1's Avatar
carb help
allright, so i put an open element air cleaner on my car the other day and set the tension on my av flap at "0". it ran good for a couple of days but now it idles at around 1800-2000. what happened. i had it tuned up today and the guy said that it has something to do with my open element. anyone have this problem? help plz!! btw its a rochester 4-bbl on a 305
Old Nov 27, 2002 | 05:06 PM
Damon's Avatar
It has nothing to do with the open element air cleaner.
The usual culprit is that the choke isn't opening and you're sitting on the the fast idle cam that gets engaged when the choke is on. The usual reason for that is that you knocked the wire off the choke elment that heats up the choke. Single wire going to the round black thing on the pass. side of the carb. If it's not that then make sure nothing is physically jamming the choke and it's related linkages on that side of the carb from opening.
Old Nov 27, 2002 | 08:36 PM
chefdan1's Avatar
what exactly does the wire connect to? is it the one that runs from the carb to the single-snorkel air cleaner? would i just put the wire back on and let it dangle??
does any one have a diagram of this??
Old Nov 27, 2002 | 08:49 PM
chefdan1's Avatar
i think i figured out my prob. i have about 9-10 volts on my alternator. is this the prob??
Old Nov 28, 2002 | 12:59 AM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Well
If your alternator is going bad it will try to run faster to compensate. You could try your return spring maybe its caught on something. Your throttle plate may be sticking. Maybe your linkage is in a bind causing it to have shiorted travel making the carb not go all the way down. Hope this helps.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
