??? About this Holley carb...
Old Dec 23, 2002 | 04:12 PM
BillZ28's Avatar
Car: 84 Z28
It is a 600 cfm Vacuum Secondary 4-barrel carb with electric choke. It says it has a Ford Automatic Kickdown lever. Does that mean it won't work on my car??
Old Dec 23, 2002 | 05:48 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
No it doesn't mean that, just don't use the kickdown.
You'll need to add a tab to hook your TV cable too though,
but that's true with any carb you get when you run a 700R-4.
Old Dec 26, 2002 | 08:41 PM
Nordbert's Avatar
I'd call the holly tech line to see if they had a bracket to bolt onto
the Holley throttle bracket for use with a 700-r4. It may not fit on the carb with the Ford lickdown linkage, however. The 700-r4
TV cable must be pulled at a specific rate as the throttle is opened. Too slow a rate can lead to tranny failure( fried clutches and/ or band).
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
