can i go any leaner with metering rods?
Old Dec 19, 2002 | 03:14 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey gusy i have a edelbrock 750 and its got the factory jets in it and I changed the metering rods to 1457 (073 x 052) to try to lean it out a little. now this did help but i need to go a little leaner. now can i go leaner by changing the rods again or do i have to change the jets to go leaner? also would a high number on the metering rod mean a leaner rod? like the (073 x 052) if that increased would it be leaner? thanks guys
Old Dec 19, 2002 | 03:31 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Yes, the bigger rods are leaner.
Old Dec 19, 2002 | 03:41 PM
Car: 89 Formula
Engine: Carbed 5.7
ok guys correct me if i;m wrong but doesn;t an engine make more vacum the higher your rev it? cause on the edelbrock website it says WOT high load low vacum and idle high vacum. that doesn;t make sence
Old Dec 19, 2002 | 04:32 PM
Momar's Avatar
Nope, idle is where you get vacuum and wot is where you lack vacuum.
Ben
Old Dec 19, 2002 | 04:53 PM
Car: 89 Formula
Engine: Carbed 5.7
ok but when i wqs messin with the vacum guage i got 9-13 at idle and at leik 1500 i got like 22 so wuts the deal
Old Dec 19, 2002 | 05:16 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Your 1500 rpm was just really a high idle because there was no load on the engine.
Mount the vacuum gauge inside the car, drive it down the road and go to WOT & see what the gauge reads then. It should be very low close to 1"hg
Old Dec 27, 2002 | 02:58 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The bigger number on the rod is the cruise jetting
the smaller number is the power setting.
You leaned out the primary power setting a lot with that rod.
You want to lean out the primary cruise setting to improve mileage. install a 73 x47 rod or a 75x47 rod and a 110 primary jet.
Use a 4" stepup springs set (yellow).
Ignition timing should be 32 to 36 total at high rpm
with 12 to 16 initial at idle (700 rpm) with 10/12 vac (ported vac)
Old Dec 27, 2002 | 11:46 AM
Car: 89 Formula
Engine: Carbed 5.7
on my edelbrock witch jet is the primary and wut is the secoundary? I think the drivers side is the primary right? cause It says i have 2 different jet sizes for them and i need to know that if i lean it out should i change both jets to the same?
Old Dec 27, 2002 | 12:32 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The primary jets are the two in the front of the carb.
The secondaries are in the rear.
Old Dec 27, 2002 | 12:42 PM
Car: 89 Formula
Engine: Carbed 5.7
are there metering rods for the secoundary jets?
Old Dec 27, 2002 | 12:44 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
rods are for primaries only.
There are no rods for the secondaries.
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
