can i tune at a high idle??
Old Dec 20, 2002 | 01:01 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i have a big cam and its hard to tune my carb by seeing when u get max rpm so would it be alright if i tuned my carb with the idle set at liek 1500 to try to overcome the lope of the cam?
Old Dec 27, 2002 | 12:17 AM
Rancid87's Avatar
no. you'll ideally want to have your idle set between 800-1000 when you adjust your mixture screws to achieve maximum vac.
Old Dec 27, 2002 | 02:31 PM
Damon's Avatar
You need to set the mixture screws at the idle speed you will normally use. If you set them at a different RPM it will likely be wrong once you drop the RPM back down.
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Sep 4, 2015 07:57 AM
ezobens
Aug 19, 2015 10:29 PM
zeitghaist
Aug 18, 2015 07:33 AM
