Quadrajet Vacuum ports
Old Dec 24, 2002 | 08:44 AM
hcl's Avatar
hcl
Anyone know the purpose of port N, located on the back of the carb? It's currently plugged on mine, and I'm wondering what it might be for.
thanks
Old Dec 24, 2002 | 09:23 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I don't know them by letter. Where is it located? On the base, leading away at a 45* angle from the brake booster? Or where?
Old Dec 24, 2002 | 09:29 AM
hcl's Avatar
hcl
It is centered on the back, near the top, and points directly toward the firewall.
thanks
Old Dec 24, 2002 | 11:25 AM
99Hawk120's Avatar
That's not a vacuum port AFAIK. Pull the plug and put your finger on it with the motor running.
IIRC it's a filtered air source for the hot air choke on the manifold...
Old Dec 24, 2002 | 08:29 PM
Momar's Avatar
If it is is a computer controlled quadrajet I think it is for the map sensor.
Ben
Old Dec 30, 2002 | 08:15 AM
99Hawk120's Avatar
Momar,
That's what the one on the base of the carb running away from the brake booster port at a 90* angle can be used for.
It sounds to me like this port is on the air horn in the back... in which case it is not a vacuum source at all.
Old Dec 30, 2002 | 01:48 PM
Momar's Avatar
Port N is the one that goes at an agle from the base from what I can see.
Ben
Old Dec 30, 2002 | 01:55 PM
99Hawk120's Avatar
Either he doesn't know which port he's talking about, that port isn't labeled N, or the letters change depending on the carb.
Old Dec 30, 2002 | 02:03 PM
Momar's Avatar
Well, I have diagrams from 84 and 86 saved on my computer and went and looked at the one on the hood of the 85 and have the carb from the 85 right here and nowhere found evidence of this port he is referring to if it is not N which is angled and for the map sensor.
Ben
Old Dec 30, 2002 | 02:05 PM
Momar's Avatar
Oh, and here is a diagram of what mine is like currently. I cleaned it up a bit. Any suggestions on what I should do with the line from the fuel tank. Should I leave the valve on there or take it off so it can vent clamp it shut or what?
Ben
Old Dec 30, 2002 | 02:25 PM
99Hawk120's Avatar
If you aren't using the purge system at all any more, remove everything else and plug the line. Then purchase a vented gas cap.
As far as the port he's talking about, it shouldn't exist on any factory 82-87 F-body carb--but he didn't say what carb or even what car he has. I have two non-computer carbs that DO have a port exactly where he describes it, and they are filtered air sources for the integral hot air choke setup.
Old Dec 30, 2002 | 02:28 PM
Momar's Avatar
I see. Where would I get a vented gas cap?
Ben
Old Dec 30, 2002 | 02:29 PM
99Hawk120's Avatar
Any store should have one. Find one for an old Chevy that looks similar and it should fit.
Old Dec 30, 2002 | 02:31 PM
Momar's Avatar
Sounds good, thanks for the help.
Ben
Quzyle
Oct 15, 2015 03:35 PM
2012sergen11
Oct 13, 2015 07:38 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
