holley wont run right
Old Dec 24, 2002 | 04:10 PM
midnightcamaro's Avatar
my dad has a holley carb on his truck it is a holley 625cfm(or sumthin) street avenger vaccum secondary. but heres the deal. it keeps sputterin and wont stay running. its like it keeps loading up. now it will only stay running with the float all the way at the bottom but in the sight glass it looks like the gas is at the top. but if u raise the float up any it wont stay runnin. its only got 65 jets in it and a 6.5 power valve this is on a stock motor and i figure thats good. we changed the power valve still nuttin. please help. thanks
Old Dec 24, 2002 | 04:14 PM
Jester's Avatar
Re: holley wont run right
Originally posted by midnightcamaro
[B] now it will only stay running with the float all the way at the bottom but in the sight glass it looks like the gas is at the top. [b]
That would be either too high a fuel pressure or a faulty needle/seat.
Old Dec 24, 2002 | 04:16 PM
ok thats sounds good we kinda thought that it might be a faulty needle seat but i know the pressure isnt to high. but ill keep u posted thanks for the advice
Old Dec 24, 2002 | 05:48 PM
82camaro's Avatar
Car: 82 camaro SC
Or faulty float(taken on fuel making it heavy).
Old Dec 26, 2002 | 10:49 AM
evil t/a's Avatar
Replace the float
Old Dec 26, 2002 | 10:56 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Needle and seat, or a pin hole in the float. I would Take the carb off and clean it first, it might have gotten trash in it somehow. Put it back on and adjust the float level. It should be right at the bottom of the sight plug. If that doesnt work, replace the float.
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 19, 2015 10:02 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
