Performance change after switch???
Old Dec 31, 2002 | 07:30 PM
88ROC1LE's Avatar
Just wanting to know if the swap from TPI to carb using the same motor, heads, etc... on L98 changes performance? I figure gas mileage may change, but how about e.t's? Would I notice a difference if I did the swap on my 88 L98?
Old Dec 31, 2002 | 07:48 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
You should gain a bit of performance as the enging will not run out of air as quickly as the TPI does.
Old Dec 31, 2002 | 07:59 PM
Jester's Avatar
You will see a significant improvment, but not a huge one. It's still gonna be a motor with stock heads and a stock puny cam. The biggest good point of a carb is that you CAN go to a good cam/heads, and not go backwards on performance because of limited programming and a mismatched intake.
Infested
May 22, 2018 11:56 PM
NBrehm
Aug 25, 2015 11:49 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 02:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
