Fuel lines
Old Jan 3, 2003 | 04:10 AM
jeff85iroc's Avatar
Fuel lines
This may sound stupid but i have to ask.
I am converting from TPI to carb and on the TPI setup there is 2 fuel lines running to the injection,but with the carb there should only be 1 right? Do i just block one of the lines off.
Also on the drivers side firewall i think it is the ESC and some sort of relay next to it will i need them for the carb install or can i take them out.
I have searched but could not find the exact answer.
Jeff.
Old Jan 3, 2003 | 05:00 AM
biff85ta's Avatar
Car: 04 Vette
One line should be the fuel feed the other is a return line which even with a carb you should still need as the pump on my 85 lg4 has a fitting that connects to the return line
Old Jan 3, 2003 | 07:19 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
If you are going to use the intank pump on your original TPI car you need to use the feed and return line. A common way of doing it is using a Mallory 3 port regulator, Summit # MAA-4309. This will cut down the pressure for your carb setup and send the excess fuel back to the tank through the return line. If you do a search for the Mallory 3 port regulator its should yield some posts with pictures.
Old Jan 3, 2003 | 06:16 PM
jeff85iroc's Avatar
I think i will just disconnect the return line and run a holley electric pump.
Thanks for the reply's
Jeff
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
