How do I hook up my electric choke?
Old Jan 9, 2003 | 03:39 PM
FRDH8R's Avatar
Ok, 84 TA with 305 and newer Edelbrock carb. The electric choke is totally disconnected, i can see the two blades where wires are supposed to go. How do I hook it up? Can anyone help. I'm getting sick and tired of holding my foot on the gas for five minutes in the morning before it warms up and can idle!
Old Jan 9, 2003 | 05:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
At some time in its life, your car had an electric wire going up to an electric choke. It was just one wire, which had 12vdc going to it when the ignition was on and the alternator charging because the choke thermostat was grounded internally.
Your Edelbrock is not grounded internally, so one of the terminals needs to be hooked to ground (the carb itself typically suffices). The other terminal needs to have 12vdc switched power supplied to it, either via the orginal wire in the harness, or via a wire that you run yourself.
Old Jan 9, 2003 | 07:08 PM
FRDH8R's Avatar
Ok, so one's ground, and one's switched power, preferably thru the ignition right? Thats what I had originally figured, but it doesn't hurt to ask.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Gordonr1973
Sep 29, 2015 11:59 AM
