jet combos needed for spring HELP
Old Jan 26, 2003 | 01:48 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Well,
this is for the motor in my sig. It's a 305, with a 2000 stall, 700R4, 3.27 gear, factory tires, crane .454/.454 cam
Wondering what jets to start out with upon initial start-up. It is a 3310 holley. I was also wondering if this has the metering plate in the back or a metering block? I saw the post by Kingtalon and wondered about my carb.
Last year I had my carb "tuned" by a performance shop and it ran worse than when i brought it to them(bought the carb brand new from summit). They jetted it very rich. Any thoughts?
Steve
Old Jan 26, 2003 | 10:56 PM
xpndbl3's Avatar
Car: 1984 Z28
by factory tires...i meant factory size 245/50/R16
anyone can help?
Old Jan 26, 2003 | 11:10 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Use a #70,71 or 72 primary jet.
The stock metering plate on a 3310 is a #21. It is equal to a #75 jet. If you have a secondary metering block use a #80 sec jet. Use a 6.5 power valve.
Your optimine jetting will be real close to this.
Real hot days with high humidity will want a little leaner jet.
Cold, clear, dry days will favour a bigger jet.
Old Jan 26, 2003 | 11:52 PM
xpndbl3's Avatar
Car: 1984 Z28
F-bird
thanks a lot. you always reply with a huge amount of knowledge and I appreciate it when you take the time to answer my questions.
customblackbird
Aug 15, 2021 10:16 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
