Stalling when i lay on gas
Old Mar 7, 2003 | 10:09 AM
jdrafke's Avatar
WEll i was wondering, when i hit the gas to the floor from like a 5-10mph start, i either get a bog or ill get a 1 second stall and then take off. How can i fix this? does it have something to do with the air/fuel mixture?
Old Mar 7, 2003 | 11:17 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Make sure the accelerator pump cicuit is functioning properly,
that the passages & nozzles are clear/clean,
the linkage for the plunger is hooked up properly and adjusted to the best setting,
and that the plunger itself is in good shape. The rubber plungers only last between 3 and 5 years of everyday driving because the alcohol added to gasoline attacks the rubber. They are not expensive to replace.
You may want to double check your ignition system & timing curve as well because most carb problems turn out to be ignition problems.
Here's a pic of the accelerator pump linkage:
explaination of the parts is on the site listed below the pic.
http://www.cardomain.com/member_page...217306&page=26
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dbrochard
Oct 3, 2015 12:43 PM
amcnellis
Sep 16, 2015 04:16 PM
rjcme
Sep 5, 2015 01:23 PM
