Testing M/C Solenoid?
Old Mar 10, 2003 | 04:33 PM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
Is there any way to test a Mixture control Solenoid? Long story, check the post I made in the DFI/ECM board if intrested.
I jus need to know if the M/C Solenoid I got from the junkyard is good or not...
THanks!
Old Mar 10, 2003 | 07:26 PM
hank's Avatar
what kind of carb is it? for a quadrajet you need to warm up the engine and connect a multimeter set on dwell in the 6 cylinder mode connect the positive clip to the M/C solenoid pigtail connector. Atatch the other end to a ground be mind full of touching other things hose clamps any other thing that might interfere with the readinglet the engine idle at part throttle it will read between 5 and 55 degerees and will be varying. this varying will verify that the m/c is working and the ECM is varying the mixture according to my rochester manual hope this helps
Old Mar 10, 2003 | 08:43 PM
Jurrel's Avatar
Car: 1984 Firebird
Sorry, its the V6. Thats the Verijet carb.
Old Mar 10, 2003 | 10:41 PM
hank's Avatar
E2SE varajet manufactured by Rochester. You can use the same test procedure as mentioned above hope this helps
Old Mar 11, 2003 | 12:09 AM
Jurrel's Avatar
Car: 1984 Firebird
Great! Thanks, hopefully the replacement Solenoid is good and its jus the ECM....
Old Mar 11, 2003 | 02:53 PM
Jurrel's Avatar
Car: 1984 Firebird
Okay I need some clarification
one should the pigtail still be connected to the MC Solenoid?
and two which is the positive? The pink/black 12V wire or the light colored one from the computer?
if I am supposed to test it with the pigtail still connected how do I connect to any metal of the wire without stripping it?
Old Mar 11, 2003 | 10:48 PM
hank's Avatar
not sure wich one is the positive you will have to check by keeping your ground hooked up on your meter and probing you should be able to push the prob in between the the wire and the pigtail where the wire enters the conector off hand i would have to say its the one runnig from the ECM but it would be best to check. let me know how this turns out for you:rockon:
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
