efi to carb help please
ok ok.... i know some of you will give me a load about an engine swap problem but no one seems to be able to snwer my question over there soo here it goes.... my 88 camaro is a v-6 and in the repair manual it tells me the car has an in the tank fuel pump i was just wondering with my new 350 can i still use that fuel pump or is there some extreme measure i will have to take in order to breathe life into my new 350
thank you for reading my post
Car: 87 IROC-Z
Engine: 350ci
Different people do it different ways. You could drop the tank and install a sump and a mechanical pump on the block. What I did was to use the factory in-tank pump and bought a Malloy AFPR # 4309 I think. This way I didn't have to run fuel lines or drop the tank.
Transmission: 4L80E/4L80E
Well, the way you asked the question was a little disjointed over there.
But,...
If you use the in-tank pump, you must use a 3-port regulator that returns excess fuel to the tank to control pressure to the carb. If you use a dead-headed regulator (2-port), the pump will not have the flow it needs to keep itself cool and will burn up.
Another alternative is to use the in-tank pump (with the regulator) as a "pusher" pump to a mechanical pump mounted on the engine. Personally, if I was doing it, I'd use the in-tank pump w/reg by itself. Others will disagree, of course, primarily because in-tank pumps have been known to fail, but you need to weigh the pros and cons of each approach and make your own decision.
But,...
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Well I ran a return-style Mallory FPR and kept my intank pump. However mine was originally a 305 TPI car and it has worked fine. But I have no idea if the V6 pump was the same as the V8 pumps, or is too weak for a 350 or what...
2012sergen11
Oct 13, 2015 07:38 PM
efiguy
Sep 27, 2015 01:30 PM
Damon
Sep 26, 2015 04:29 PM
