Running Rich...
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Running Rich...
I dont know a whole lot about tuning q-jets, how do i lean it out a little bit? I can smell the unburnt gas when Im driving, and puffs a lil black smoke on startup...thanks
You should check your choke to make sure it's opening all the way, that's a fairly common problem. I know there's an excellent thread on adjusting chokes here in the carb forum, believe it's from about a year ago.
Before trying the choke adjustments, check your vacuum lines for cracks or looseness. On my carbed '89 Olds wagon the line going to the choke pull off was cracked and dried out. That was causing a too rich startup and occasional flooding.
Car: 91 Z28
Engine: LB9
Transmission: WC T5
the choke is also good lol, and i dont think there is any cracked/missing lines because I just rebuilt the topend of the motor like last week, and if any hoses looked in bad shape which none really did i replaced them.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
