hood clearance
hood clearance
got a quick question about hood clearance, '85 firebird 305 stock intake, i'm putting on a carter carb, i'll have to use a carb spacer-adapter, what air cleaner will i need, will it clear with a flat base air cleaner, or will i need a drop base? any ideas on how much of a drop?
thanks
david
thanks
david
Transmission: 4L80E/4L80E
You will need a drop base. Measure your current air cleaner's drop, add the spacer thickness, minus about 1/2" - that's the new drop you'll need.
Good luck.
Good luck.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
