Still not tuned right
Old Apr 5, 2003 | 12:41 PM
jdrafke's Avatar
Well guys i have given up on trying to tune this carb. I had an old 2 barrel on it and this edelbrock 600 seems to be runngin worse. Does anyone no how i can get this properly adjusted? WIll the local shopp have a carb tuner and do those usually work dead on?
Old Apr 6, 2003 | 07:05 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
what have you tried so far?
Old Apr 7, 2003 | 11:12 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Here's some pictures and information about your carb:
http://www.cardomain.com/member_page...217306&page=26
The most important thing is to make sure everything is perfectly clean including all air-bleed passages, and working correctly before you try to start tuning.
Old Apr 8, 2003 | 02:24 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: Still not tuned right
What have you tried and what is it doing (loading up, bogging under WOT, etc)
Old Apr 9, 2003 | 07:12 AM
chev69's Avatar
Hey man i have an edlebrock carb on my truck. It's a 500 cfm and i had problems tuning at firts to. So my dad ended up showing what was up and all he did was turned the screws all the way in and started from scrach. Then once he got it turned to where he wanted it he then played with the timming. Since then i havne't had a problem with it. But did you buy it new or used. Because when they come new from the factory there usually just ready to bolt right on. But buying a used one you never now.
Zell1luk
Sep 29, 2015 10:36 AM
