Fuel pump and throttle linkage questions
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
I'm in the process of putting in a new 80gph fuel pump and I noticed that it only had an inlet and outlet but the stock had what I believe to be a return line,inlet,and outlet.
How should I go about plumbing my new setup?
Problem number two which really isn't hard to fix but I'd rather do it right than rig it up or fabricate a bracket of some sort.
I have a weiand stealth intake manifold and a 600 cfm carb with a cheap throttle linkage bracket but the throttle cable and the transmission cable thing (Some call it the "TV") are too short.
I'll post pictures soon.
Thank you
Thank you
Car: '86 Trans Am
would that create a vacuum of some sort in the tank and cause a problem with the fuel pressure?
Does anyone have anything to say about the trottle linkage?
Just get a vented gas cap and for your tv cable look here www.700r4.com
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
