Carter Linkage...
Old Mar 26, 2003 | 02:08 AM
z28redline's Avatar
Car: 1986 Camaro Z28
Engine: 305 lG4
Carter Linkage...
I just got a Carter 625cfm p/n#9635 and I was wondering if someone could post pics of how the linkage is hooked up. To hook up the cruise control on my car could I use the adaptor Edelbrock has for their performer carb?
Thanks in Advance,
z28redline
Old Apr 4, 2003 | 01:24 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
automatic/manual?
is your camaro automatic (700r4)? if so, you will need a linkage adapter for the throttle valve cable from the tranny (to achieve proper t.v. cable geometry). Otherwise, you will burn up your tranny (not instantly, but within 15,000 miles)... the adapter is available from b&m.
Old Apr 4, 2003 | 02:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't worry about the TV geometry, it will be fine. You can probably use Edelbrock parts for your cruise.
Old Apr 4, 2003 | 04:43 PM
thirdgen88's Avatar
Car: 1995 Corvette
tv geometry
perhaps fine enough to drive, true... but how long I question...
Old Apr 4, 2003 | 06:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The TV geometry on the Carter throttle arm is the same as on the Qjet.
Old Apr 5, 2003 | 09:37 AM
thirdgen88's Avatar
Car: 1995 Corvette
sorry...
sorry about that, I forgot that there actually are differences between edelbrock and carter...
Old Apr 5, 2003 | 05:35 PM
z28redline's Avatar
Engine: 305 lG4
Thanks for the help guys, I went out and got the cruise adaptor for a performer carb. and I should be installing it some time this week.
z28redline
skinny z
Carburetors
Sep 29, 2015 11:25 PM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
makaveli09
Sep 15, 2015 10:43 AM
firebird305
Carburetors
Jul 5, 2001 09:26 PM
