Which jets do I have/which do I need
Old Apr 14, 2003 | 02:36 PM
TBI305Camaro's Avatar
Im running a 670cfm holley street avenger on my 350. It is definetly getting to much fuel. I need to go down a couple steps on the jets. My question is...which jets do I have right now? Im gonna try going down 2 jets and see what the car does. Other than fouling plugs the car runs really good. Im probably loosing MPG tho...and some power. Least I know im not running lean lol.
Old Apr 14, 2003 | 04:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Before we talk jets, let's establish a few other things first:
How are you delivering fuel, and controlling pressure? Are the float levels set correctly? What distributor are you using?
As to jets, I don't know what size is in there now. But, a good investment is the Holley Jet Assortment Kit, which has 2 of each size from 66 to 99. You won't use them all, but you'll have everything you can use, and if you get more than a few pairs, you'll spend close to what the assortment will cost you.
Old Apr 21, 2003 | 10:42 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
This is tbi305camaro BTW.
I havent touched the floats. I have a mallory fuel pressure regulator putting out 5.5 PSI. The carb is just as it was when I bolted it on.
Im no carb expert yet so I may take it and have it adjusted this time.
Im using a brand new proform distributor. HEI. brand new coil, cap, rotor came with it. After the tranny install I ran the car for maybe 5 min total and the brand new r45TSs are already fouled out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
69GTOby
Apr 18, 2016 02:34 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
mackjar66
Sep 14, 2015 01:17 PM
