New carb...huge flame shoots out =O
Old Apr 18, 2003 | 10:33 AM
BillZ28's Avatar
Car: 84 Z28
So yesterday I finally got my Holley 600 CFM VS carb installed by a garage that got it running. Today I have the hood open and have the car running and I give it gas and then all of a sudden, a huge flame shoots out almost burning my face. So uhh, what the hell is the deal with this? Thanks.
Old Apr 18, 2003 | 11:12 AM
BillZ28's Avatar
Car: 84 Z28
Oh yeah, and does anyone know what to do about singed eyebrows and eyelashes?
Old Apr 18, 2003 | 11:14 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Well after reading some off your site, it looks like you changed much more than just the carburetor, so it could be a number of things you'll just have to start checking out.
Old Apr 18, 2003 | 02:17 PM
BillZ28's Avatar
Car: 84 Z28
Yeah, I put on an Edelbrock Performer, Accel Distributor and cap, Holley carb. My initial thought was timing, could it be something other than that?
Old Apr 18, 2003 | 02:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check the timing first. In the "old days", we used to say, "75% of carb problems are fixed with a set of plugs & points." Well, we don't use points anymore, but the concept is still the same - Get the ignition up to snuff before messing with the carb.
If the ignition is properly set up and adjusted, then you're looking at a lean condition. Most likely the accelerator pump, but could also be power valve or jetting.
Old Apr 18, 2003 | 02:42 PM
BillZ28's Avatar
Car: 84 Z28
Ah crap, you think I blew out the power valve? I heard that's common on Holley's.
Old Apr 18, 2003 | 03:12 PM
BillZ28's Avatar
Car: 84 Z28
Well actually Summit here says the 4160's have no jets, power valves, or accelerator pump. The exact number is 80457S if you want/need to know what exactly the carb is.
Old Apr 18, 2003 | 03:26 PM
ronterry's Avatar
Car: '94 Corvette
4160's have jets on the primary, but a metering plate on the secondaries. You have a Vacuum secondaries, so you don't have a secondary accelerator pump. You do have a primary pump though.
That 4160 probably has power valve blow out protection, but it should have a primary power valve.
Did you by any chance gun it when the engine was cold, and the choke open?
That would explain the lean back fire.
Hell - mine dosn't have a choke, and if a stomp on it cold it will shoot up.
The Edelbrock (no cloke) I had on previous, did not do this 'AS BAD'. Not sure why the eddies don't flame up like the holley's when cold?
Ron
Old Apr 18, 2003 | 04:22 PM
BillZ28's Avatar
Car: 84 Z28
Do you think that would do any damage to anything?
Old Apr 18, 2003 | 05:03 PM
ronterry's Avatar
Car: '94 Corvette
Just your eyebrows and eyelashes
I double checked on Holley's website, and yes that model has power valve protection. ohhhh and it's shiny
Ron
Old Apr 18, 2003 | 06:28 PM
BillZ28's Avatar
Car: 84 Z28
Yeah and the front of my hair, it didn't seem to like the mousse I had in my hair either.
I guess I'll make sure to leave the throttle alone while the engine is still cold.
Old Apr 24, 2003 | 04:09 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Thats called a "holley Haircut".
Old Apr 24, 2003 | 02:17 PM
BillZ28's Avatar
Car: 84 Z28
:sillylol:
Old Apr 29, 2003 | 02:21 PM
blue86z28's Avatar
whoa
Just be glad u didnt just put a fresh coat of hairspray on!
Old Apr 29, 2003 | 02:47 PM
BillZ28's Avatar
Car: 84 Z28
I did have mousse, that wasn't pretty.
Old May 2, 2003 | 08:19 PM
Dan88IrocZ's Avatar
How did you fit a moose in your hair?
Old May 3, 2003 | 03:36 PM
Momar's Avatar
I would think he would have about had to fit a his hair under a moose to do that, but it would take an awful lot of talent to do that and work on the car at the same time.
:lala:
Old May 3, 2003 | 04:01 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
make sure the distributer aint in 180 off if you changed the intake
BillZ28's Avatar
Car: 84 Z28
No no no no, I have a moose for a hood. The antlers work really well as a brush guard.
Old May 3, 2003 | 05:32 PM
Momar's Avatar
Rock on. Screw painting my car, I am going to do it in animal skins. lol
Old May 11, 2003 | 01:47 PM
CaysE's Avatar
You probably singed the fur on your moose hood, too. Might want to consult the appearance board on fixing it.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
2012sergen11
Oct 13, 2015 07:38 PM
meeklay812
Oct 1, 2015 03:46 PM
3.8TransAM
Sep 27, 2015 08:37 PM
