Holley 4160 to 4150 Conversion Kit
Old May 4, 2003 | 11:55 PM
1982Camaro383's Avatar
I have a Holley 4160 and the Secondaries have no metering block no jets, just a metering plate. Is it worth while to install the conversion kit to a 4150 and if so how much power gains will be achieved.
Thanks,
Justin
1982 Camaro
Old May 5, 2003 | 08:47 AM
82camaro's Avatar
Car: 82 camaro SC
Not really a gaurantee of power gains, just allowing you to adjust more stuff. If you are lean or rich on the secondary side, then yes you have the potential to gain some HP. In my experience, most plates are pretty close for stock/mild street cars. You can compensate some with the primaries if needed. Example, if you are right on, on the primary side on your A/F mixture, but at WOT you are lean--then yes the kit will help.
With your mods, you might consider selling the VS and getting a 750DP.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
LittleFranks
Oct 7, 2015 11:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
