Need tips on removing carb!
Parting out my 83 Z which has an Edel 550 carb. Never removed one before. Is there anything I should know about before I dig into the little project? Also removing the Edel Performer intake. Any precautions other than draining antifreeze, I should take?
Thanks,
Brandon
Thanks,
Brandon
Transmission: 4L80E/4L80E
Make sure everything is disconnected before you try to pry it loose with a screwdriver.
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
dont mess the float adjustement
also dont turn it upside down... it has to do with the float inside...
You may also want to keep some of your vacuum tube & plastic joint, very usefull to have spares.
Hello, Michael
Aug 20, 2015 03:19 PM
