i'm lookin for a new carb
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i was wondering if any of you have any suggestions. my set up is in my sig. i also need something that i can run with the computer and electronic choke. thanks alot.
Car: 1986 Irocz
Axle/Gears: 3.25:1
With 408 cubes you sure don't want to run a factory Qjet or the factory computer.
To feed a 408 you'll need to completely upgrade your fuel system and use a performance carb of at least 750 CFM.
Well, that's assuming that you're planning to get significantly increased performance from your 408, and not just duplicating factory 400 performance.
A Carter or Holley carb fills the bill by being adequately adjustable and having large enough fuel bowls to feed a healthy 408.
I'm biased but I'd use an Edlebrock 750.
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
Just curious, but dosent the factory Q-jet flow 750 cfm.
And if you plan on keeping the computer then there's no aftermarket CC carb out there that I know of.
I think you could probably get that cc qjet tricked out to run more of a performance set up, but that is also a guess.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Try these guys out..heard good things when they came up with pther q jet guys.
http://www.jetchip.com/fuel/default.cfm
Car: 84 camaro Z28
Engine: 434sbc
thanks for the replies. i do need run a cc q-jet. i haven't seen any aftermarket cc q-jets.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
