Quadrajet CFM Numbers
Old Jun 25, 2003 | 12:55 PM
Blackhawk355's Avatar
Car: 1989 Firebird
Engine: N2O 355CID
What's the CFM numbers on a stock Qjet for an 84 Z28 w/ a 305?
Old Jun 25, 2003 | 02:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Same as almost any other Q-Jet, about 750 CFM or so, except that if it's a LG4 carb, it has this little metal tab that limits it to about 625 CFM that you can grind off, to allow the secondaries to open all the way, and make it bog worse if it isn't tuned right.
That's the wrong question to ask about a Q-Jet. Basically it doesn't apply. It's not like a Holley or something, where there are actually different carbs with differnt size bores and therefore different flow capacities.
Old Jun 26, 2003 | 07:09 PM
Damon's Avatar
Officially it's an 800 CFM carb since it uses the larger primary bores that bump up the CFM slightly over the old 750 CFM units. However, it is limited to about ~625 CFM due to the secondary air valve being limited to less than it's full 85-90* opening. Like RB said, grinding down the stop to get full opening will get you full airflow capability.
And don't be all freaked out about an 800 CFM carb on a little old small block- it'll work just great. The QJet's design basically eliminates the possibility of bogging due to over-carburetion, if properly tuned.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
Dragonsys
Sep 25, 2015 03:51 PM
