dose a power valve saver , work ?
hi i would like to know if those power valve saver work ? are they hard to put in ? is there one thats better than another ?
any info would be great !
thanks chad
thanks chad
Car: 4
Engine: 6
Transmission: 5
Yes.
No. Takes about 2 minutes to install.
There's only one kind I know of, you get it from Holley and follow the instructions.
All it is, is a check ball. It allows vacuum to get to the power valve but prevents spikes of positive pressure (backfires) from getting to it, thereby protecting it from the backfire.
Car: '94 Corvette
I only know of (2) kinds. Ones that installs in the mainbody, and ones that install in the base plate.
The Holley addon installs into the main body, requiring a drill. It come with a drill bit, stop, springs, & check *****.
Ron
Ron
1992rs/ss
Jan 31, 2025 05:10 PM
NBrehm
Aug 25, 2015 11:49 PM
