rochester feed tubes
Old Jul 17, 2003 | 05:13 PM
imstress's Avatar
I am trying to rebuild a Q-jet and it look like the last guy in crushed one of the fuel feed tubes. Anyone know were I can get new feed tubes? the carb is a rochester Q-jet #17085227 0646 HLZ I don't know what it came off of?
Chuck
Old Jul 17, 2003 | 06:01 PM
Damon's Avatar
Get any old junkyard QJet and swipe them. I assume you're talking about the tubes in the air horn casting back by the secondary bores. Same tubes from any QJet will work. Be careful getting them out of the old carb- they don't come out easy unless you get lucky. I have gotten in the habit of lock-titeing them in place when I install them so they don't vibrate back out. once they've been in and out a few times they get a little loose.
Old Jul 17, 2003 | 07:27 PM
imstress's Avatar
best i can due at my local junk yard is $30 for a used carb. I was hoping they were a 5-10 dollar item new. but you got to do what you got to do.
Chuck
Old Jul 18, 2003 | 04:03 PM
Damon's Avatar
Chuck- if you have a local swap meet or flea market you can get a whole box full of junked QJets for about $10. Swipe what you need and resell them to the next guy for the same $10.
Old Jul 18, 2003 | 11:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
While you got them out might consider drilling 4 small holes through the center of the emulsion tubes about the size of a pen tip. This trick helps transistion into the secondaries better. This is basicly the only internal modification so what the hay.
Old Jul 19, 2003 | 07:11 AM
imstress's Avatar
I have seen this mod before. does this allow some gas in sooner to reduce the bog when you punch it?
chuck
Old Jul 19, 2003 | 02:16 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
chuck
In a sence yes. It allows fuel to pass quicker and smoother so if the secondary tesion, rods and hangers are all perfect it completes the rest of the equation.
no green
Jan 9, 2016 09:22 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
dusterbd
Sep 29, 2015 08:40 AM
