demon question
Old Jul 22, 2003 | 05:30 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
demon question
yea, if i looked through everything, it'd probably have an answer, but i noticed that on my carb's baseplate, the timed vaccuum port deal thats milled into the baseplate has a twisty peice of metal about 1/4" long, with what seems like a small ball on the end of it that is right over the top of the hole that goes up into the baseplate...i hope thats a good description, is that twisty sliver of metal supposed to be there?
Old Jul 22, 2003 | 10:22 PM
Engine: V8
ok, well atleast tell me where i can get an aircleaner that fits, my edelbrock air cleaner interferes with the choke mechanism
Old Jul 23, 2003 | 06:28 PM
Engine: V8
ok, well the thing in my timed vaccuum port was a machining defect, and it's been corrected.
the air cleaner needed to be a flat base instead of the drop base i got away with on the edelbrock carb i had before
now the only problem i have is that i've never tuned a carb with a four corner idle, and for some reason, the carb makes a VERY high pitch loud whistling noise until the rpms are over about 3500-4000
Old Aug 26, 2003 | 07:44 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
i just bought a demon card a few months ago.....more than enough trouble with it already.in your manaul it tells you how to ajust it.just the other day i was having trouble with the secondarys so i took it apart,a pile of aluminm was in the bowl and i took one jet out and a large amount of aluminm fileings came out of it....should have that kind of crap with the price you half to pay!works awsome when its in good tune
Old Aug 26, 2003 | 07:47 PM
EvilCartman's Avatar
Car: '82 Z28
I haven't had one problem with mine. Been easy to tune, no defects and it doesn't whistle.
New2Chevy
Oct 4, 2015 11:27 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
