fuel line
fuel line
I am going to put a new fuel line in my carbed 87 RS, do i need a return line going back to the tank? Plus there is a vacuum line going to the tank, what is that line for? Also, can i buy a performance fuel pump that can be mounted right inside the tank.
Transmission: 4L80E/4L80E
You can put a high-volume electric pump in the tank. If you do that, you'll need to use a regulator with a return line to the tank.
You don't really have a vacuum line to the tank. You have a vent line that once (at least) went to an evaporation charcoal canister up in the engine compartment. It's not a bad idea to keep that canister.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
