ATTN: Jester
Old Aug 5, 2003 | 02:13 PM
lbrohez's Avatar
From: Decatur,, IL USA Search Posts:NONE.............. Whore Posts: All.................
ATTN: Jester
I am running a holley 3310 (750 vacuum secondaries). I have a 350 (Stock LO5) (has same cam as LO3) and it has Stock rebuilt LO3 heads on it. It has about 10.3:1 compression. I have a cast iron intake manifold with a 1 inch adapter/spacer under my carb. 2 inch air horn inbetween my holley and my open element. I have a L98 exhaust manifolds, y-pipe, and I-pipe, with no cat and no muffler. It runs about 190 degress also. I am running my timing at 4 degress right now, and have a curve kit. My question is what do i need to change to get my carb to work the best on my car like what jets and power valve ect. to make it run the best, because i have my carburator leaned allmost all the way out and i still runs rich and idles betweem 750 and 1000rpms with idle turned all the way down.
Thanks in Advance
Levi Brohez.
Old Aug 10, 2003 | 01:07 PM
lbrohez's Avatar
can anyone help?
Old Aug 11, 2003 | 11:18 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
When the idle-speed screw is all the way out but the engine still idles high, that usually means a vacuum leak somewhere.
Old Aug 15, 2003 | 12:02 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
just in reading that... it seems as if your timing is very low.
your base timing should be closer to 8-10 degrees, maybe more depending on your vacuum advance style.
get the timing right, then start monkeying with the carb.
i prefer to have the vacuum advance set on manifold vacuum. give you a boost of timing at idle and at highway speeds, smooths the idle out, and improves mileage a bit.
if you have it set up that way. with an adjustable vac advance can.. i like to run about 10-12 degrees of advance at idle through it.. so you've got about 20 or a bit more total at idle.
back the idle screw off a bit. start with the idle screws out 1.5 turns and start turning them in very slowly like 1/8 turn at a time.
until the idle smooths out. if it gets rougher start back at 1.5 turns and come out. till it smooths out.
if you've got a vacuum gauge it will help tune it for peak vacuum.
then drop it into gear.. foot on brakes of course and tweak it a bit to get it to idle nice nice.
Old Aug 16, 2003 | 12:22 AM
lbrohez's Avatar
thank you, i will try doing that, but i dont have a vacuum gauge or a automatic transmission.
Jester
Carburetors
Dec 13, 2001 09:08 PM
ede
Carburetors
Oct 20, 2001 02:39 PM
jaretz28
Apr 30, 2001 12:42 PM
SeanSullivan
Carburetors
Mar 19, 2001 12:49 PM
Jester
Carburetors
Sep 12, 2000 01:24 PM
