Problem w/ mallory 3 port bypass AFPR
Old Aug 23, 2003 | 12:36 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Ever since I have put it on the fuel pressure changes by itselt. I reset it and it will stay that way for a while then it moves again. I am running a stock TBI fuel pump through AN-6 lines and the fuel pressure gauge in front of the carb about 2 inches before a 90 degree turn where it goes into the fuel rail.
Any idea's? It's hard for me to figure out what my carb is doing if my fuel pressure won't stay still.
Jason
Old Aug 23, 2003 | 06:34 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Mine does the same thing
Old Aug 24, 2003 | 12:06 AM
mpitts77's Avatar
I had the same set up..My fuel pump suddenly died..so i just put a 7psi inline pump chunked the regulator and said fug it =D It pulls about 7psi even through the non working in-tank pump.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Reid Fleming
Oct 10, 2015 09:56 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
sahlomonic
Sep 20, 2015 07:15 PM
CatmanFS
Sep 19, 2015 09:00 AM
