Demon Carb guys
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Demon Carb guys
What type of braket are yall useing for the TV cable with your Demons? I had a braket made by TCI that hooked into the base plate on my 4150 but the Demons don't have a notch in the base plate for it.
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I cut the tab off of mine and welded a little tab down the side of the throttle bracket to keep t from turning. The tab will lay into the spacer like a little (L) shape as a stop.
Brian
Brian
86IROC112
Aug 17, 2015 02:00 PM
