How do you get fuel pump out!
Old Sep 14, 2003 | 01:34 PM
Purple Haze's Avatar
Car: 1991 Camaro RS
Engine: 383 N/A
I got the fuel tank out (sort of) I didn't bother lowering the axle but I got it out enough to get to the fuel pickup assembly (it's not exactly safe but it's all I can do), now how do I get it out of the tank. One shop manual says I need a special tool (but I'd rather not buy tool just for this) while the other says to loosen the bolts (but there are no bolts). How do I get the fuel pump out to change it!
Old Sep 14, 2003 | 01:47 PM
RP1987GTA's Avatar
on the top of the tank you will see fuel lines coming out of the tank,this is the sending unit and fuel pump assembly.You will find a RING that retains it to the tank.Carefully rotate the retainer ring counter clockwise until it releases the sending unit *** from the tank....be careful not to bend or ruin anything while turning the retainer ring.After you remove the ring the sending unit *** will be free to remove from the tank...DON"T MUSCLE IT OUT ..take your time and carefully remove it....you may need to turn it in different directions to get it out.You sould also replace the large oring under the sending unit when reassembling the unit into the tank.
Old Sep 14, 2003 | 01:59 PM
Car: 1991 Camaro RS
Engine: 383 N/A
i've looked at that ring but it seems like there are some tabs that need to be pushed out of the way.
Old Sep 14, 2003 | 02:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The whole ring turns; it's sort of like a big nut. It loosens about 1/8 turn or so and comes off.
Don't bend anything. Everything is supposed to stay straight and flat. If you bend it, it will almost certainly leak when you put it back in.
Old Sep 14, 2003 | 05:56 PM
Car: 1991 Camaro RS
Engine: 383 N/A
well, i got that ring off...i just realized that i now have to drop the rear end out of the way to drop the tank. I got all of the bolts off to drop it but now my fabbed dual exhaust is in the way so I now have to figure out how to get it out of the way to drop the rear.
Old Sep 14, 2003 | 06:49 PM
RP1987GTA's Avatar
be careful you don't stretch the brake hose trying to get the rear out of the way...best to remove it completely........
anyone know why i wouldn't be getting email notifacation on posts?...i have it checked but i get none
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
