how quick..
Old Aug 29, 2003 | 11:21 PM
Skykiller's Avatar
how quick..
Ok guys i have a 85 RS
i got it 2 weeks ago cam went flat and i found out it was just a 305(came stock with a 6) so im puting this in:
355
TWR forged pistons
stock rods and crank
GM 462 heads
454 lift cam 260 dur
EB intake
650 carb
desk top dyno says i should get around
336 at 4500 HP
416 at 3500 tq
it has 3.42 gears
what should i hit the quarter?
Old Aug 30, 2003 | 04:47 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
IMOP a 750 would do a lot better on that combo, should be a mid to low 13 on that combo.
Old Sep 6, 2003 | 03:56 PM
Skykiller's Avatar
Anyone else?
Old Sep 11, 2003 | 06:28 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
you left out 2 important things.
Whats your compression?
what is your cams duration at .050?
Old Sep 14, 2003 | 06:51 PM
Skykiller's Avatar
comp is ten and half
heres the cam info
Valve Adjustment 0 0
Gross Valve Lift 0.454 0.454
Duration At 0.006 Tappet Lift 268 268
Valve Timing At 0.006
Open Close
Intake 28 60
Exhaust 68 20
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 218 218
Lobe Lift 0.3026 0.3026
Lobe Separation 110
Old Sep 14, 2003 | 07:53 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
Re: how quick..
I would guess 13.4-13.9@ 100 or so, there are SOOOooooo many variables.
I also highly disagree with the quote(below), everyone wants to automatically throw a 750 on any 350. The 650 will make it more drivable, better fuel milage, and better throttle responce!!(No offense 1FastZ)
[QUOTE]Originally posted by Skykiller
I ran a very simular combo. Mine was a 355, TRW forged flat tops, Stock rods and crank. Ported #462 heads 64cc, Victor Jr. EB intake, 650 double pumper....this sound framiliar so far?
The difference was that I ran a bigger cam. It was a comp cams mechanical roller, it was too big(255 dur @.050 and .575lift), becuase I had a NOS system on it and AFR heads in the mail....
I ran a 13.24@108 w/ 2.4 60's (without nitrous) in a 3000lb (inculding me) S-10, getting beat by 3rd gens running 12.9@102 GRRR
So I have a 3rd gen now :hail: :hail: Now just to build it up...
Old Sep 14, 2003 | 08:38 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
No offense taken SweetS10V8. I've tried a 650 on my 355 combo and its no comparison to the 750. I was 6 tenths faster with the 750 and it pulled so much harder with the 750.
Ricco
Feb 18, 2012 03:49 PM
ChampionN84
Jul 12, 2007 04:08 PM
Fast89T/A
Feb 6, 2007 10:37 AM
sicc87
Jun 26, 2006 06:23 PM
