fuel pressure to run w/ speed demon 750 dp
Old Oct 6, 2003 | 09:20 PM
Momar's Avatar
Well, I have been been buying some goodies the last couple of days. I am getting the carb mentioned above, and also ordered a carter fuel pump. I was thinking that the pump was 7psi, but after I ordered I realized it was 8. Will this be to high? If so I have a regulator, but will it hurt a mechanical pump to regulate it down? The only carb I really have experience w/ is my cc quadrajet so I dont really know. I put a t56 in and so I really wanted a dp carb. What should I do w/ the fp. Do I need to order a different pump or can I make this work? I have run a best of 9.410 in the 1/8 mile, but it feels like I am running out of fuel up high w/ my current pump(still using quad by the way). I also have a set of sportsman II's that I have started porting and will finnish soon if I could get enough free time.
Ben
Old Oct 7, 2003 | 08:39 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Use the regulator ..set it to 6psi and run it.My Demon 750dp loves anywhere from 5.5-6.5psi.
Old Oct 8, 2003 | 12:53 AM
EvilCartman's Avatar
Car: '82 Z28
I'm running just the stock pump putting out 6 psi, no problems
Old Oct 8, 2003 | 09:33 AM
Momar's Avatar
What is the setup you are running? I have been running a quadrajet w/ stock pump, and it seems like it is running out of fuel up high. I guess it could be the carb, but I am putting a new pump on when I do the carb anyway just to eliminate that as a possibility.
Ben
Old Oct 9, 2003 | 01:14 AM
Car: '82 Z28
Speed Demon 750 stock replacement fuel pump for this engine. I'm gonna get one of those Carter pumps and a Mallory 3 port, that'll all be used when I switch to a 350. You might want to check your fuel filter and float level if it feels like you're running out of fuel.
Old Oct 9, 2003 | 07:39 AM
Momar's Avatar
Well, the carb I am running out of fuel on is the stock quadrajet, so I am not going to mess w/ it since I am putting the demon on.
Ben
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Fireslash
Apr 11, 2016 06:43 PM
meeklay812
Oct 1, 2015 03:46 PM
tattmann
Sep 27, 2015 05:20 PM
