Dieseling
Old Oct 9, 2003 | 10:44 PM
Purple Haze's Avatar
Car: 1991 Camaro RS
Engine: 383 N/A
Dieseling
Well I just got my camaro running again w/a Rochester Qjet. Something was wrong w/the Holley, my brother's working on it. Old spark plugs were completely black. Changed those, put my bros Qjet on. Now the car runs fine but its been dieseling everytime I turn it off. I changed the timing and the idle, could it be something w/the carb? The dieseling only lasts about 2 seconds. I really want to get that 383 on the road again.
Old Oct 10, 2003 | 11:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sounds like its getting too hot, or the idle is too high. How high is your idle speed? if its over 1000, its probably too high.
If not, then it may be running lean.
Old Oct 12, 2003 | 10:05 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
My car used to diesel bad. If the idle was like 1k it would diesel. I turned the timing way down...ran 93 octane...nothing fixed it.
Finally I installed a lt4 camshaft and waaallllaaaa no more dieseling...even with more timing and a higher idle...
I suspect a leaky intake gasket. Only thing I can figure.
Old Oct 18, 2003 | 12:02 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
What dist. are you running? Hei advance wieghts can stick. Try cleaning and a little lubrication on the posts underneath them. You might have too light a level of springs on them or one has come off the spring mount. Any way make sure they move freely in and out. Just a thought, It's happend to me before. High carbon deposits on the valves can cause this problem also.
Old Oct 18, 2003 | 12:37 AM
Transmission: 4l60e
Running really rich will cause carbon deposits. What happens is the carbon get so hot that it will ignite the fuel even after the ignitoin of off.
Make sure the timing is no more than 12 degrees or so at idle, and try running some 93 octane and some octane booster to help clean everything.
school boy
Oct 22, 2015 11:47 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
MoonDog
Jun 14, 2002 12:37 AM
86Trans Am
May 12, 2001 02:10 AM
