How can I run a holley with the l69 aircleaner?
Old Oct 21, 2003 | 11:34 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
Ive been using quadrojunks and they seem to be good to me.But i plan on building a zz4 with the hot cam, would a performer rpm quadrojet intake work with a modified quadrojet? Would the holley with the regular performer rpm be better? Either way id like to stick with the l69 aircleaner.
Old Oct 23, 2003 | 12:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't believe the L69 air cleaner will clear the fuel bowls (float adjustment screws, actually) of the Holley.
I found out my '66 air cleaner had the required dimples to clear the bowls, though. I had to add the snorkels.
Attached Thumbnails How can I run a holley with the l69 aircleaner?-ram-air.jpg
Old Oct 23, 2003 | 12:11 AM
five7kid's Avatar
I assume you're building a ZZ4 clone. Otherwise, the engine comes with a fine intake (see sig above).
Here's a pic of the dimples to which I referred. Not a very good shot, but they're at 3 & 9 o'clock.
Attached Thumbnails How can I run a holley with the l69 aircleaner?-air-cleaner-base.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 19, 2015 10:02 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
