shaking
Old Oct 26, 2003 | 04:32 PM
CamaroVroom's Avatar
NEED HELP!!!!
i just picked up an 85 T/A it vibrates from 1500-2500 rpms but above that it's smooth. What can it be?????
Old Oct 28, 2003 | 06:20 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Maybe it's just nervous! Does it do that in N or when your driving in gear? In N, bad cam or inconsistant compresion between cyl. or bad harmonic balancer. In D, wheel balance, bent rim, or bad drive shaft! Might even need a tune-up, they don't run too smooth on 7 cyl.
Old Nov 2, 2003 | 10:45 AM
icebird_1981's Avatar
maby the cam was changed i got a high lift cam in my car and she shakes all the time.
Old Nov 2, 2003 | 12:29 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Good motor and tranny mounts? If they are shot, that will shake the car.
Old Nov 19, 2003 | 06:41 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
If it's only when you step on the gas, bad spark plug or wire or cap.
Old Nov 21, 2003 | 04:38 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
mines got great mounts and such, but with that cam, she shakes like a ****
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
xxx3man`
Sep 23, 2015 10:37 PM
88rscamar0
Sep 23, 2015 09:08 PM
Amillionoh7
Sep 5, 2015 11:44 PM
