Jet recomendations?/? ,,holley guys inside.
Old Nov 23, 2003 | 06:25 PM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
sup guys,ive got an 84 L69 5spd transam ,its pretty much bonestock,except for emissions delete,and a weiand dual plane intake,it had a holley 600 vacsec on it,i just swapped my 650 holley DP on,4150 # 4777 on.
current jetting is 57 fronts,74s rear,this is how it was when i got it,it runs great,around town is perfect,still getting about 23 mpg like i was,however on the WOT runs,it bogs when the secondaries open. if you ease into the 2ndarys,its fine,just takes off and goes,it you mash it WOT it kinda bogs for a split second,then you get the intake howl.
what are you guys running as far as holley setups on your 305s? any and all help is apreciated it.
Old Nov 23, 2003 | 08:35 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
i don't know much about carbs, or holleys for the most part but it sounds like your secondaries are opening too fast.
Old Nov 24, 2003 | 07:20 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I would leave the jetting alone for now and go up 2-3 sizes on your rear shooter to get you over the "hump" until the secondary main system takes over.
Old Nov 26, 2003 | 10:09 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
first of all you have dp on your car so you should not make such a big jump on your jets it should be no bigger then two sizes's from fronts to back. you should have 67's in the front and 69's in the back. i think that should fix your problem.
second you should make sure that your rear ap is ajusted properly.
Old Nov 27, 2003 | 09:33 AM
EvilCartman's Avatar
Car: '82 Z28
Not sure if Demon and Holley do things different but from the factory, my Demon had a spred of 7 jet sizes. #76 and #83 Also have read on here that the spred can be around 6 to 8 jet sizes
Old Nov 27, 2003 | 07:24 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
not sure about a demon carb but on a holley you shouln't have such a spread. you car install it into your car and it will still run but it should run better when they are atleast a 2 jets spread.
fasteddi
Sep 2, 2015 10:29 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
355tpipickup
Aug 19, 2015 10:02 PM
86IROC112
Aug 17, 2015 02:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
