choke fuse needed?
Old Dec 1, 2003 | 07:55 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
choke fuse needed?
Do i need to run a fuse inline to my electric choke on my holley 750 VS? I was thinking a 5 or 10 amp? which is needed?
Old Dec 1, 2003 | 09:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've never used one. Never had any problems, and I'm not a particularly "lucky" person.
Old Dec 1, 2003 | 10:17 PM
xpndbl3's Avatar
Car: 1984 Z28
ok that's what i thought I didn't know if i would cause a need for concern
Old Dec 4, 2003 | 07:50 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Re: choke fuse needed?
There should be a fuse line readily available that leads from the fusebox, over to the Choke Heater Relay, then over to the Carb.... I believe it's 20 AMP..
If you sill have the stock wiring, and Relay.... why not?
Old Dec 4, 2003 | 08:24 PM
xpndbl3's Avatar
Car: 1984 Z28
stock wiring somewhat.....relays....well who knows....this car has been gutted, unfortunately not by me....so wiring is definitely fun, although i've fixed most of it.
Ghettobird52
Jul 5, 2024 11:18 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
