Bad air flow?
Old Jan 13, 2004 | 09:03 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Bad air flow?
This might sound like a silly question, but I'm gonna ask it anyway.
Which would be better, a dual snorkel air intake, or a single snorkel air intake but with the ram air system on induction cowl bonnets?
Or, what about a system that did both? Now, if you had a set up that had both, would the air turbluence from the two air streams from the snorkel and the air coming down from the ram air system interfere to the point that it would cause more harm than good?
Old Jan 17, 2004 | 09:26 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Air coming from one place is your best bet. But make sure you engine gets all the air it needs because if it doesnt youll want to add a second snorkel.
Old Jan 19, 2004 | 01:00 AM
Car: 1989 Trans Am
Cool. Thanks for your reply.
Old Jan 19, 2004 | 01:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The stock LG4 single-snorkel, even if set up for "ram", is too restrictive for even an unmodified LG4. You need the 2nd snorkel.
And, "ram", isn't, really. "Cool air inlet" is closer to reality.
Old Jan 19, 2004 | 03:52 PM
Car: 1989 Trans Am
If I made a dual snorkel system by using a snorkel from another single snorkel system and attached it to my existing setup, would that be a good way to go? I could improve the air flow further by enlarging the inlets by cutting the snorkels close to the THERMAC valve and then run tubing to the front of the car.
Sound like a good idea?
Old Mar 17, 2004 | 10:43 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3.73 posi
I was also searching around for info about a ram air style air cleaner assembly and found this company that builds them in all different heights, styles and configurations. Don't know if they are still around since their price list is a few years out of date but still looks interesting. I am strongly considering buying one.
http://www.ramairbox.com/parts.html
Old Mar 20, 2004 | 04:53 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
yes they are still around. super chevy had a review last year on the ram air box. they ran it on a BB nova and it got great results. they said it was worth every penny. they do make different setups to fit your application too
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
