850cfm Holley
Old Jan 22, 2004 | 11:52 AM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
850cfm Holley
Do you think an 850cfm holley double pumper would be too much for a 383?
Old Jan 22, 2004 | 12:58 PM
EvilCartman's Avatar
Car: '82 Z28
Depends on what the 383 has in it.
Old Jan 22, 2004 | 03:07 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
It has CR3 rods, speed pro hypereutectics, gear to gear timing, vortec heads port/polished machined up to .6" lift, 1.6 roller rockers, hedman long tubes, cam will be somewhere around 240/250 @ .050 with around .500/.500 lift, with performer rpm manifold.
Old Jan 30, 2004 | 09:48 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
No. Obviously you'll have to play with jet size, but you'll be fine.
Old Jan 30, 2004 | 10:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 850cfm Holley
Depends upon your stall speed (if automatic) or launch RPMs (if manual). If the RPMs are too low, it'll bog on you. However, if the stall (or launch) is high enough to get you in your cam's powerband, the 850 should be okay.
Might still be more than you "need", but should be okay.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
