holley quick change jet system
Old Feb 1, 2004 | 02:29 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i was wondering if anyone ever used this. i hate having to pull the fuel bowl off the carb just to change jets. this doesn't sound like a bad investment for 35 bucks. this is the one im looking at:
http://store.summitracing.com/defaul...part=hly-34-25
let me know what you guys think of this product or if you have any other reccomentations. thanks alot.
Old Feb 2, 2004 | 05:54 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Used them on my race cars for a long time, excellent thing to have if you make alot of jet changes. Cuts the time and aggravation of having to remove the bowls in half.
Old Feb 2, 2004 | 06:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
need one for the secondaries, too http://store.summitracing.com/partde...=HLY%2D34%2D26 .
Shoot, eliminate fuel draining completely http://store.summitracing.com/partde...HLY%2D55001HOL .
No more often than I rejet, I'll pop the bowl. However, if someone gave me the kits...
Old Feb 2, 2004 | 07:13 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
I owned one of the Adjust-A-Jet kits when they were known as Percy's. Not worthwhile IMHO. Biggest problem was you never knew what your baseline was. With jets is you need to jet up a tad, say from #72's to #74's it is dead easy. With the needle valve type, you never really knew what you were getting. Should I go up one notch...or two? You really had to test to find out. Then there was the problem of remembering where you had the stoopid thing set. Gasket quality was also very poor, and they did require special gaskets
I finally gave it up and got my Weber Powerplate
9192camaro
16
Feb 3, 2019 12:21 AM
fasteddi
Sep 2, 2015 10:29 AM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 19, 2015 10:02 PM
